Alright I searched but couldnt find anything, I also looked in the FAQ. The FAQ said to use quick detailer that it is the best lubricant for the clay. The system came with one bottle but just in case I need more I had already bought some NXT Speed Detailer. Is it alright to use the speed detailer or does it not work as good as the QD? Thanks
Clay bar which lubricant?
The NXT Speed Detailer should work just fine and someone correct me here if I am wrong but the sole purpose for even using any sort of liquid detail spray is just to keep it lubricated between the paint surface and the bar of clay. So if I am right here it won't matter which detailer you use as long and there is some form of slick lubricant between the clay and the paint.
Trent W.
2002 Ford F-150 SuperCrew FX4
2002 Chevrolet Tahoe LS
Well murr really my question came from one of your posts. You said that you thought QD got more contaminants up than the speed detailer, unless I misinterpreted your post.A realitycheck is a time in your life where you do a check of your heart. A time you check where your relationship with God is and where it's going. Then you make a decision as to where your going from here.
Yeah, I think that the QD works better. It seems to grab most stuff on the first pass or two. But this is purely my opinion.
I have a feeling the Nxt Detailer almost makes the surface too slick, almost like the Last Touch does, but not to that extent. Last Touch needs diluted 1:1 with water because it makes the surface so slick the clay cant grab dirt.
You can clay just fine with the Nxt Detailer, but you might need to make a few passes over each spot just to make sure you get everything.2017 Subaru WRX Premium - WR Blue
There are ingredents in the NXT stuff that add more shine. Those ingredents are very slick. Too slick to use for clay. It will work with clay but using regular QD is better.You left out licking the water off. Oh, wait a minute, that's my cat, not my car. Uh, I mean my cat licks himself dry. I don't lick my cat dry. Or my car. -PC.
Thanks guys for all the info. Since it came with a bottle of QD i'll use it. If it runs out I might have to use the spray detailer. Thanks again for the help, I love this forum. Great knowledge.A realitycheck is a time in your life where you do a check of your heart. A time you check where your relationship with God is and where it's going. Then you make a decision as to where your going from here.
Agree with Newport Viper...
We do not recommend the use of water and soap, it can prematurely deteriorate the clay.
The use of Quik Detailer, Speed Detailer, or even Last Touch ( at a 1:1 dilution) is what will give you the best results overall.
MikeMike Pennington
Meguiar's, Inc.
800-854-8073
mpennington@meguiars.com
Mike2016 Focus ST
QD and Speed Detailer need to be "as is"...You do not dilute them like Last Touch
MikeMike Pennington
Meguiar's, Inc.
800-854-8073
