Big Problem
  • Big Problem
    Hi there guys i have a problem and i dont know what to do , my car gets parked outside and every morning the sprinklers get hold of it now unfortuneately these sprinklers are attached to my borehole. Now a residue has been left in the form of white droplets it has covered my entire bonnet and left hand side of my car , i have tried a couple of things to get rid of them but to no avail does anyone know what i can try to get these marks off , any help will be greatly appreciated !
    Re: Big Problem
    It sounds like whatever chemical is in the water has left some pretty nasty deposits, and it has started to etch into the surface. Have you tried working with a paint cleaner yet? If not, you may want to try something like Scratch-X...
    Then, use one of the mist and wipes like Quik Detailer daily to prevent the spots from etching.
    Rick McDonough
    1.800.854.8073 * 3853
    rmcdonough@meguiars.com
      Re: Big Problem
      Hi Traffies,
      Welcome to Meguiar's Online
      Here's an article on our forum that discusses the two different types of water spots or etchings on our forum in the Hot Topics forum. We'll copy and past the link below. The how-to article is fairly in-depth and will explain more detail but in a nutshell you'll need to either use clay or a paint cleaner as Rick alluded to and in some cases you 'll need to use both.
      Then afterwards, you'll want to apply a coating or two of wax because claying and using a paint cleaner will remove any wax on the paint.
      Here's the link to the thread,
      How To Remove Water Spots off Automotive Paints
      Type I Water Spots - Mineral deposits sitting on top of the paint
      Type II Water Spots - Etchings below the surface
      Close-up of same photo above
        Re: Big Problem
        Thanks alot mike i will give it a go and see what happens will let you know !
