Water Stains in Automotive Glass
  • Water Stains in Automotive Glass
    What is the proper way to remove stains from automotive glass?
    Thanks,
    Markus Ros
    Hi Markus,
    Welcome to Meguiar's Online!
    Let me get back to you on this.
      if you have an old clay bar laying around give that a shot. Is the water etched into the glass? What have you tried so far?
      Chopped 55 Suburban
      99 3.0 CL
      Family cars:
      1958 Eldo Biarrittz Vert
      48 Merc Woody - a true sleeper
      New project: 67 Sunbeam Tiger
      Newest project: 66 Mustang Vert
        My $0.02
        If the glass is not etched but spotted with hardened mineral deposits, then thoroughly wet a towel with vinegar and lay it on the window. Let it soak for several minutes. The vinegar should soften and dissolve the minerals. Keep the vinegar off the wax as it will likely remove it.
        If the glass is etched you can try 0000 steel wool or DACP with a PC. This will most likely not remove all the etching but might reduce it.
        Follow up either process with a glass cleaner and RainX or similar product.
        Jim
        My Gallery
          The clay bar did not work, but I will try the vinager.
          A local company offers a product that contains a bottle with an unknown chimical and a piece of steel wool. I defenetely want to stay away from that.
          Sincerely,
          Markus Ros
            I've had good luck with vinegar, although you should try to avoid getting it on the paint. It is acetic acid and could harm the paint.
            Another good approach would be to use a cleaner/polish that is designed for glass cooktops. The brand we have in the house is Weiman Glass Cooktop Cleaner (http://www.weiman.com/cooktop.html), and it does a great job on waterspotted auto glass.
