swirls and scratches
  • swirls and scratches
    i am a total newbie at detailing cars.
    i need some info on what products to use to remove scratches and swirls.
    i have multiple cars that need this kind of work done, should i use a d/a buffer since I'm an amateur?
    Slick Nick's Auto Detailing
    Re: swirls and scratches
    Depends on how bad they are. You could use ScratchX and a lot of elbow grease. If you have more than one car, this method can get old quick. If you can afford a D/A that would be the way I would go. D/A's are pretty easy to use, so don't sweat that part.
    AeroCleanse, LLC
    www.aerocleanse.com
      Hey Nick,
      Since this is your first post, Welcome to MOL!
      ScratchX is a great product if working by hand, but if you can I would invest in a G-110 dual action polisher.
      Andy
      101impala
      Andy M. Moderator
        With multiple cars you definitely want a DA buffer. In fact, if you go to autodetailingsolutions.com and check out their "DA Polisher Promotions" link on the left side menu you'll find a "Package #2" that will give you everything need to get started and enough product to polish and wax multiple cars. I would recommend that you pick up a dozen more microfiber towels though.
        Autodetailingsolutions has great pricing and excellent customer service.
          You might want to read these links over as well so you understand the full proces:
          Step 1 Wash
          Step 2 Clean
          Step 3 Polish
          Step 4 Protect
          Step 5 Maintain
          Suggested Products for Taking Care of a New Car
          How To Remove Swirls By Hand
          Each one, teach one... Ferrari Fiorano 355 F1 Spider
            Welcome to mol. The d/a is easier to use then it seems. I was so hesitant at first. Now its the only way to go. Good luck.
