I have been looking into getting a small pressure washer for things like undercarriage washing, etc. I realize the potential problems of blasting dirt into the paint, but my question is what PSI is sufficient for auto use? I don't need a crazy one but might want to use it on the driveway once in a while. The PSI produced from coin-ops seems to do the job, but I don't know what PSI they run at. Suggestions?
Pressure Washer PSI???
Re: Pressure Washer PSI???
I'm not an expert by any means, but I have a 2500 PSI pressure washer that works well for our driveway. Most pressure washers have a lower setting that would help with washing under your cars.
PS: Mine is made by Briggs & Stratton and has a wand that has the higer and lower setting built into it. Some pressure washers have little bits that go on the end to make the pressure higher, depending on the appliaction of course.NOTE: Post count does not reflect actual detailing knowledge.
I have a 2750psi electric unit but I have it turned down to about 1500-1750psi. Can't imagine needing anything more than that.
Rasky
Id be weary of Karchers, I've owned 3 of the electric models from 1500 PSI to 1750 PSI and after about a year of moderate use, they would start cycling. I will never buy another one.
I recently switched to a Campbell Hausfield 1800 PSI and so far, so good.
Pressure Washers Direct - Shop huge selection of quality pressure washers from top name brands. Buy power washers direct. Free Shipping. Expert Advice.
They have some fantastic information on pressure washers there. Basically from what I gather, it isn't just PSI that you should be looking at, rather GPM (gallons per minute) as well. An electric pressure washer may have a high PSI, but its GPM is very low, meaning it has a low cleaning power. A gas or high end electric model on the other hand will have a much higher GPM, meaning much more cleaning power. When looking into electric, remember there are two types; induction and brush motors. The cheap $100 pressure washers are usually going to be universal/contact/brush motors, meaning they will tend to wear out fairly fast, usually dying out in a years time. Induction motors though will keep on powering on and last years much like the gasoline models.
I agree with Wolf-strong, pressurewashersdirect is where I bought my Campbell Hausfield after reading the reviews on it there, they also have top notch customer service as I bought a refurb and the one they sent me was defective origionally, but they were more than willing to help me and got back to me very quickly with another unit.
