Deep scratch on hood - Ideas on how to fix/make better?
  • Deep scratch on hood - Ideas on how to fix/make better?
    Hello,
    I tried using some techniques I learned from a Meguair's Detail Day from Mike Phillips a few years back today . Mike is a great teacher, but unfortunately, I was not very successful with the task at hand.
    Situation:
    My coworker's hood got keyed. When I looked @ it, it didn't seem "that bad" - none of the keying seemed to go straight thru the paint, most of it seems to be in the clear & some may have reached the color layer.
    What I tried:
    - #83 Dual Action Cleaner/Polish - didn't do much; applied by hand as well as w/ Meguair's Porter Cable
    - ScratchX - did very little; applied 3-5 times slowly w/ passion by hand, and then a few times using the porter cable, and another 3 applications by hand.
    This is a picture of what the scratch looks like (before):
    After the polishing/scratchx, still lots of work to be done - spent 2 hours on it, and don't think I accomplished much:
    I think most of the difference in "before/after" is just my lack of camera image capturing skills, it was getting darker, so the scratch doesn't look as apparent.
    Any suggestions on what I should try next? More ScratchX (I used a good 1/4-1/3 of the bottle)?
    I saw Mike teaching someone to apply touch up paint & wet sanding the scratch w/ 2000 grit sand paper, but I don't want to make things worse on my coworkers car - I also don't want her to have to spend 400-500 getting the entire hood resprayed for such a relatively small scratch.
    Thanks for the help!
    Re: Deep scratch on hood - Ideas on how to fix/make better?
    It may be beyond scratchX and a DA.
    It's hard to tell from the pics, but it looks pretty deep. May be time for the next step......touch up paint, sand paper and a rotary
    2008 Meguiar's Batmobile Team
    2008 Meguiar's/Ford SEMA Team
    2009 Meguiar's/Ford SEMA Team
    2010 Meguiar's/Ford SEMA Team
      imo that looks pretty deep for scratch x
        It looks like that paint is metallic. A brush touch-up and wet sanding will not work. It's going to take a whole hood repaint. If she has comprehensive insurance that should be covered -- vandalism.
        Tom
          Yeah that scratch is thoroughly out of DA-land.
            from the second picture it looks real deep, most likely to deep for repair without repainting
            Jon's Premium Auto Detailing
            210-281-8151
              That scratch is out of RB-Land and even Wet-sanding Land, it's all the way across the Universe and into Touch-up Paint Land and even Body Shop Land.
                My goodness. Aren't you in a cheery mood this morning.
                Tom
                  I have had great success using M105 by hand to remove scratches and bird poo etching, you could give that a try. I think it might remove the scratch between the white/bright areas in your photos, but those areas look to be much deeper.
                  1999 Ford Contour SVT
                  Silver Frost/Midnite Blue
                  1966/2760
                    I really appreciate all the replies guys. If I remember correctly, she has a $500 deductible, quote for repainting my friends hood (similar situation but scratch went through to primer) was in the $400-$500 land. Her's will probably be even more. I guess she'll hold off for now - I put a coat of wax after the polishing on the entire hood, so at least the scratch is shiny .
                    body shop land, here it comes, hahaha.
                    Thanks again!
