Hi, sorry if this is in the wrong forum but I'm new round here and am a bit confused as to what products I can use.
I have a Mini which I stripped the bulkhead/engine bay to bare metal and after etching up painted with some rust proofing (POR-15), then top coated with primer/top coat.
The Top coat was done using Cellulose Spray cans (sorry prob not the level of finish most of you guys are used to, but gotta start somewhere
). The finish isn't bad (definitely better than it was and good enough for a daily drive Mini) but it needs buffing up.
There are a few areas (flat places where I have a couple of small runs)which I was thinking about colour sanding with some 1500 grit, but what do I use to buff it up after?
And also I think the whole newly painted area needs cutting/buffing, and I have been recommended to use Meguiars but cannot tell which products I should use.
Any advice appreciated!
![BigGrin](https://www.meguiarsonline.com/core/images/smilies/biggrin.gif)
