Hyper Dressing?
  • Hyper Dressing?
    This stuff is really expensive and I see that a lot of people use it on the tires and stuff. What exactly is this and what can it do/ and what can it be used on thanks.
    Matt
    Re: Hyper Dressing?
    I know a few people use it for dressing tires. It isn't really that expensive I didn't think? Isn't it around $30 a gallon?
    Navy Blue Metallic Pearl 2002 Camaro Z28: Build in progress. (416" LS3/9" Rear End/TH400/200 Shot)
    Superior Blue Metallic 2005 Trailblazer LS: !Badges/!Molding/20% Tint/Stealth Audio in Progress
      Re: Hyper Dressing?
      How does hyper dressing compare to ASD? I've been using APD for tires and exterior trim for a while now and I really like it. Not too shiny and seems to last for a while. Even after rain.
        Re: Hyper Dressing?
        When you really think about it Hyper dressing is like 4 different dressings in one. What I mean by this is that it is dilutable to 4 different gloss levels from 1:1 for high gloss to 4:1 for I believe a satin finish. So purchasing 1 gallon can give you a high gloss dressing for tires to a satin finish for engines and interior work. This is a very versatile product that yields many uses from 1 gallon.
        Andrew
        2013 Race Red F-150 SCREW
          Re: Hyper Dressing?
          ASD should last longer on the exterior. But for interior things, it is very glossy, so some people dont like it for that.
          Hyperdressing can be diluted to different shines, so many poeple make two bottles for themselves as mentioned above.
          As far as the cost, remember you are getting between 2-4 bottles worth with the dilution, not 1.
            Re: Hyper Dressing?
            Nailed it!
              Re: Hyper Dressing?
              I can't decide between Hyper Dressing and M40
              AeroCleanse, LLC
              www.aerocleanse.com
                Re: Hyper Dressing?
                More better cleaning with M40
                Both are great products though...
                  Re: Hyper Dressing?
                  I like #40 for the interior and Asd for the exterior. Just my preference.
                    Re: Hyper Dressing?
                    Hyperdressing is expensive if used at full strength. It is ment to be diluted which break down to one heck of a deal. I picked up a gallon but I really only plan on using it for engines, I have ASD and have used it a couple times so far on wheel wells and really like it a lot.
                      Re: Hyper Dressing?
                      I just got done using some Hyperdressing on both the engine compartment and the wheel wells and it looks great. Here is my concern though, will the hyper dressing attrach dirt and grime like some tire dressings do? Some tire shines I have used are like an oil and all the dirt and brake dust sticks to it so the next time I go and wash my tires my sponge is shot because it becomes all oily and filthy. Is hyper dressing the same? And how does hyper dressing differ some ASD?
                        Re: Hyper Dressing?
                        Before I found this forum I asked Rick at ADS a similar question. I have a stock engine, but show it at a lot of Cruise Ins. I need something that wouldn't attract sand & dust and Hyper Dressing was recommended. So far, it appears to be doing the trick. Definitely better then the other stuff I've used.
                        Rick
