I left some masking tape on my trim and the sun melted the adhesive. What can I use to remove the adhesive without damaging the black trim?
Removing adhesive from trim
Re: Removing adhesive from trim
Originally posted by RogueGypsy View PostI've used, WD-40, rubbing alcohol (91%), Goo Gone and Tarminator. They all do the job without damaging paint. If the adhesive is thick a plastic razor blade helps too.
Radkonn, I found that Meguiars PlasticX will work well, too, but you have to work it in hard. Try some of that on either a foam cutting pad or a terrycloth bonnet.1991 Honda Accord EX Sedan; daily driver; 0-60mph 7.625 seconds top-end of 2nd gear @ WOT.
