I recently purchased a new hood for my car since it was dented. It looks great when I purchased it but I felt a slight crack on the hood but I didnt think it was a big deal. I took it home and today I decided to wash/clay/polish it to see if theres anything going on with the hood. I realized there was and its this weird spider crack on it. (possibly from something falling on it) but then something tells me its more then something falling on it. can anyone tell me whats going with it? and more importantly, how to REMOVE IT?
Removing spider cracks on hood
Re: Removing spider cracks on hood
Bad problem and tough fix.
Top coating will only make it worse, sand and polish afterwards and you will only have a worse spot.
It looks like solvent lift by someone placing a solvent wet pad for a while or wet solvent accidentally poured on it?
Short of the whole repaint you can only start with 400 wet dry and wetsand to the metal (perhaps the primer if lucky). Then spot prime with a high build primer like Duplicolor sandable primer. Block out with 400 and or 1000 grit.
You can minimize the area by masking the affected area out about 2 inches past the bad spot before priming.
Then top coat and wet sand with 2500 then APPLY An CLEAR COAT over a slightly large area and buff in about a few days (assuming spray can lacquer).
LOOKS LIKE A SPOT FOR A RACING STRIPE OR DECAL??
