?? on using M80/83
  • ?? on using M80/83
    first time using the M80 was @ the last Thurdays night open garage class (Oct2) on my white gmc sierra. my truck had swirls all over and using the M80 w/ a 2.0 cutting pad on half my hood took care of my swirls. since then, i ordered the M80 along w/ M83, M105, D151... the list goes on. my ? is to those that have M80. how often do you use it on your vehicles and is it safe to use it everytime you clay?
    Re: ?? on using M80/83
    Well if you follow proper washing and drying techniques, you shouldn't need to use it that often.
    How to Wash Your Car (ShowCar style!)
    Ryan
      That said, using #80 on a polishing pad is completely safe to use every couple months.
      But if you are doing it often, you could move to a milder cleaner like #9/#82.
        Ryan
        makes sense! i just like the idea of m80 being a cleaner & polisher. just one less step i need to do when doing the 5 step cycle.
        hey thanks all for the quick replies! is this the mildest cleaner/polish? or should i just... clay (when needed)> color x> nxt2.0? thanks again!
          Upon correctioned made, start with proper washing and maintainance. If swirl is back..always start with least aggressive product. M82 (least aggressive) > M80 > M83 and so on.
          Ps : why would you u wanna get D151 and M105 at same time ?
            D151 and M105 are two very different products, with two very different uses.
            M105 is a fast cutting compound with a cut rating of 12 (top of the chart), where as D151 is an AIO (All-in-one) product that has a medium abrasive and wax in one product.
              why not? they're totally different products.
              EDIT: ^^plus the same reason on what Mark said.^^
                I really do not see a problem using #80 a couple times a year. The main thing is to get your technique down. This way you will not instill any more swirls in the paint. Good luck.
                  when I was able to detail my cars and truck on a more regular basis(every 2-3 months) I would use 80 every other detail. Now that my job rules my life I detail everything about every 6 months and use 80 everytime I detail. 80 is my go to polish because it is rich in the same trade secret oils as 7 and it leaves the paint very wet so I can kill 2 birds with one stone. No need to use a dedicated pure polish.
                  Andrew
                  2013 Race Red F-150 SCREW
