Hi everyone. I'm new to the forum and I'm hoping your expertise can help me. I have a 2006 Nissan Murano. I got it back from the detailer and immediately noticed 4 patches of paint that were lighter than the rest of the hood. The largest spot is about the size of a half dollar but irregularly shaped. The finish feels smooth and doesn't feel like there is damage. It seems as though it's deep in the paint layer or something. After checking the TSBs, there is one about discoloration caused by the protective plastic they apply to new cars (NTB99-060c), but it is almost 3 years old.
Is anyone familiar with this problem? Could this have somehow been caused by the detailer? It doesn't seem to be anything residual from the wax or polish. The finish feels as smooth as glass like the surrounding paint, it's only visually different.
I have a theory. I think moisture has seeped into the finish. TSB NTB99-060c, PAINT SWELL/STAINS/SPOTS UNDER PAINT GUARD FILM, states:
quote:
"If a Nissan vehicle exhibits swelling, stains or spots on the paint finish (which appear milky
or whitish on dark colored vehicles and dark-shaded or coffee-colored on light colored
vehicles) immediately after the PGF is removed, the cause may be moisture collection
under pockets/creases of the PGF. The paint may absorb moisture which may cause the
affected paint finish area to temporarily discolor... The size of the swell, stain, or spot may range from a dime to a clinched fist and have an
irregular shape..."
The detailer used pressurized water when they washed it. Could this have forced moisture under the finish? The bulletin basically says to let it dry out in the sun (if it's warm, which it isn't) or use a heat gun. It says that it must be repaired within a short time or it will be permanent. I really don't want the detailer, who is not a paint technician, to try to fix this. I can only see them making it worse. I wonder if I could bring this to Nissan?
I've attached a couple pics that I've boosted the contrast in order to highlight the spots.
![](http://i33.tinypic.com/348m6u1.jpg)
A close-up of a spot. The 2 small, black spots are nicks from pebble strikes. I don't think this is the cause of the discoloration because the other 3 spots have no damage nearby.
irregular shape..."
![](http://i33.tinypic.com/5n6vxy.jpg)
