Hmmmmm, good question. Maybe when the pad gets softer than original and the velcro is holding up as well??? I.e the velcro doesn't stick to the backing plate as well??? I'm not sure on this one, only throwing out ideas,,,,,,deadman98
Originally posted by deadman98 Hmmmmm, good question. Maybe when the pad gets softer than original and the velcro is holding up as well??? I.e the velcro doesn't stick to the backing plate as well??? I'm not sure on this one, only throwing out ideas,,,,,,deadman98
Sounds good to me.
I'm so new at this I hadn't had this come up yet. What about when the pads surface kind of gets pitted and the foam cells are tatty and torn??
What scrub said, you might see bits of foam coming off when you polish. I have one of my finishing pads on its last leg. I'll try to revive it if I can ,otherwise time to crack open a new one.
Originally posted by Bill D What scrub said, you might see bits of foam coming off when you polish. I have one of my finishing pads on its last leg. I'll try to revive it if I can ,otherwise time to crack open a new one.
Hey Bill! How do you revive the pad? Do you do any kind of washing to the pad to let the residue come off the pad? I'm really curious since pads are really expensive..
I was wondering the same thing. What has worked in the past (against Meguiar's recommendation) to help remove built up product is to use a small stream of water from the kitchen sink and a nylon bristle brush. I rinse the pad very lightly. Just enough to moisten the top of the pad and mostly the caked on product. Then I lightly spread the water and try to gently remove the caked product. Seems to do a good job and minimizes damage to the pad. I then dry the pad by placing the pad on a towel and pressing the water out. By not soaking the pad with water will prevent the velcro from getting wet and coming off.
