I have a 95 Honda Del sol that my daughter insists on parking in front of the sprinklers, and since they are my sprinklers it is my fault her cars finish is all spotty. She has tried the white vinegar on the windows but that didn't work all that well. the car spent some time in SF by the ocean so the finish is a bit rough. Now it is in the central valley of CA, where the sun takes its toll. do you thingk the best solution is to clay the car? or just attack it with a wire grinding wheel (just kidding). and then a good waxing?
water spots
Re: water spots
Yes, try claying the vehicle...If that does not remove the water spots, then use a light Paint Cleaner, such as Deep Crystal Paint Cleaner. It will quickly remove them. You can use it on the windows to. For future window Cleaning get the Detailer Line Glass Cleaner, or the NXT Glass Cleaner. Both in which work greatMatt
Re: water spots
doboca1,
Check out my first post on this detail. It'll answer your questions on the window watermarks. After completing the rest of the detail, watermarks on the painted surfaces were also removed using the procedure stated in the thread. Good luck!
We encourage MOL members to show off their latest before & after results. We also welcome "Work in Progress" Threads. For Enthusiasts or Professional Detailers
Accepting Rep Power points.
