Hey, this is my first time posting after reading for about 2 weeks now, I have learned a lot. I am currently trying to restore a decent finish on a Black 94 Acura Integra. It is my brothers old car which he so nicely killed the finish for me. It was parked for a while on the street so it has water spot galore on the windows and paint. I am currently going to do everything by hand and have picked up some Ultimate Compound and Swirlx. I have a couple questions, one would be what other products and steps should I use to remove minor scratches and heavy water spots. Also I was wondering if I could use a different product other than M04 to remove water spots on windows by HAND, could I use UC or SwirlX? Thanks a lot for any future help and I am looking forward at the project I have ahead of me
Water Spot removal
Re: Water Spot removal
Originally posted by dude808 View Post
I am currently going to do everything by hand and have picked up some Ultimate Compound and SwirlX.
Just as important as using the right product is using the right technique, for example when using UC by hand to remove below surface defects you want to lonely work on a small section at at time, that would be approximately anywhere from an 8" square are to a 16" square area depending upon how hard the paint is, how deep the defects are and your skills and abilities to work paint by hand.
You certainly can't tackle half the hood at one time and that's because removing defects mean removing paint as explained here,
Also, before applying ANY product over the entire car, dial-in your system by doing a Test Spot.
TEST SPOT
Doing A Test-Spot
Before going over the entire car, see if you can make just one small section look good, that is apply the product you're planning on using over the entire car to just one small section about a foot squared or so. Work it in and then wipe it off, then apply the polish, work it in but not as much as the compound because now you're not trying to remove paint, just spread the product out, then immediately wipe it off, then apply the wax and let it fully dry and then wipe it off.
Now inspect our results. Make sure you can make one small section look GREAT before going over then entire car. If you can't make one small section look GREAT you won't be able to make the entire car look GREAT.
Make sense?
It should look like this,
Originally posted by dude808 View PostAlso I was wondering if I could use a different product other than M04 to remove water spots on windows by HAND, could I use UC or SwirlX? Thanks a lot for any future help and I am looking forward at the project I have ahead of me
I just went out and tried Ultimate Compound on some mineral deposit water spots on the glass of my truck with a foam applicator pad and it worked just fine to remove these spots and restore a very smooth, clear surface to the glass so give it a try on your car's glass and remember to put a little passion behind the pad if there's a lot of built up gunk and contaminants on the glass.
