Body Solvent
  • Body Solvent
    I have a gallon of body solvent. It says in the directions to only use on clear coated paint. What happens if the paint is unclear coated?
    Also, are most bumpers clear coated?
    If you have tried Body Solvent please tell me your opinion and what you use it on.
    Re: Body Solvent
    I was thinking about picking some up as a bug/tar remover, but I might be wrong, need to check.
    2018 Subaru Outback 3.6R Touring - Crystal White Pearl
      Re: Body Solvent
      I know you can use it for bug and tar.
      Thanks for the Reply Though
        Re: Body Solvent
        Clear coat is paint
        Therefor if the car has not cc or single stag it still das paint
        As far as the bumper go, all painted surfaces will have cc, some more than others ie: the top might have more than the bumpers. But I could be wrong on the latter.
          Re: Body Solvent
          Thanks!!
          That is what I was Looking For!!
          It will be my Bug and Tar from Now on, instead of Turtle Wax Bug and Tar!!
            Re: Body Solvent
            Where does it say only to use on clear coated paints?
            My gallon and spray bottle do not mention anything about that.
            Chris
            Dasher Detailing Services
              Re: Body Solvent
              You are right Chris!!
              I do not know where I saw it now.
                Re: Body Solvent
                I really wouldn't worry about that warning...
                Clear Coat is referring to paint. If it doesn't have it than it's single stage paint.
                Bumpers are painted the same as the rest of the vehicle as well.
                Matt
                  Re: Body Solvent
                  Not true. I have had multiple cases where the bumpers and flares were painted with single stage paint, while the rest of the body was clear coated.
                  Just to repeat, there is NO warning on the D130 Body Solvent suggesting the product cannot be used on clear coats.
                  Chris
                    Re: Body Solvent
                    Question: Will Body solvent remove wax when used to remove bug and tar?
                      Re: Body Solvent
                      Yes it will remove wax.
                      Jason
