Im going to Swirl X my car by hand to get minor/light swirls out. My plan is to use the Swirl X then Deep Crystal Polish then M-26. Does this sound ok? Also do I need to remove the old wax for the Swirl X to work properly, or will the Swirl X do this for me? Thanks in advance.
Using Swirl-X
Re: Using Swirl-X
i'm sure someone else will probably chime in here in a sec, but from what I understand just having a good washed car should be just fine, the somewhat abrasiveness of the swirl x should remove any was you may have on the car. Sorry to hear you are doing this by hand. Also with the process, the swirl x should probably leave the surface ready for LSP, for some comparisons that I have read says that it is just as good if not better than 80 and that leaves a paint surface LSP ready.Fergy-
