How large working area for 1 circle of product on the 2.0 Pad With DA Polisher G220?
  • How large working area for 1 circle of product on the 2.0 Pad With DA Polisher G220?
    Hello friends, some questions. I just bought a Meguiar's DA polisher G220 (Asian version). I am using 83, 80, Cleaner wax and NXT tech wax with my DA.
    For one circle of product on the pad, how many times I can put the product on different working area? I'm not really sure about this
    How wide is one working area? in foot and centimeter 1 foot x 1 foot?
    How many passes needed for 83, 80, cleaner wax and NXT Tech Wax?
    Thank you for your answers
    "Does it come in black?" Bruce Wayne / Batman Begins
    Re: How large working area for 1 circle of product on the 2.0 Pad With DA Polisher G2
    How to apply product to the face of your foam buffing pads
    Below is how to apply fresh product to the face of you foam buffing pad when first starting out and your pads are dry. After you break you buffing pad in by working this initial amount of product over a section of paint, you can cut down on the amount of product you're using as the pad will be less likely to absorb as much product as it will become damp with product.
    This can be found on the forum homepage, actually it's in the center and towards the top so it's easy to find.
    How To use: G110 - G220 - G100 - PC/Porter Cable - UDM
    If you're moving up to machine polishing, be sure to read the below thread before starting...
    Tips & Techniques for using the G110, G100, G220 and the PC Dual Action Polisher
    (These are all similar tools)
    There is no answer to this as there are too many factors, things like,
    How deep the defects are you're trying to remove
    How hard or soft the paint is
    Your skills and abilities (Huge factor)
    That's why we are always teaching people to do a test spot and make sure you can make one small area look good before going over the entire car. When you do your test spot you'll find out how many passes or applications it takes to remove the swirls and scratches, then the idea is repeat this process over the rest of the car.
    TEST SPOT
    Doing A Test-Spot
    Before going over the entire car, see if you can make just one small section look good, that is apply the product you're planning on using over the entire car to just one small section about a foot squared or so. Work it in and then wipe it off, then apply the polish, work it in but not as much as the compound because now you're not trying to remove paint, just spread the product out, then immediately wipe it off, then apply the wax and let it fully dry and then wipe it off.
    Now inspect our results. Make sure you can make one small section look GREAT before going over then entire car. If you can't make one small section look GREAT you won't be able to make the entire car look GREAT.
    Make sense?
    It should look like this,
    And if you're having any problems, the post back here after the test section and we'll help you tweak your technique to insure you get it right.
      This actually covers just about everything this is to know about getting good results with a DA Polisher...
      After teaching hundreds of classes here at Meguiar's, there are some common mistakes most people make when trying to remove swirls and scratches with a dual action polisher. Most of them have to do with technique.
      Here's a list of the most common problems
      1. Trying to work too large of an area at one time.
      2. Move the polisher too fast over the surface.
      3. Too low of speed setting for removing swirls.
      4. Too little pressure on the head of the unit.
      5. Too much pressure on the head of the unit so the pad quits rotating.
      6. Not keeping the pad flat while working your product.
      7. Too much product, too little product.
      8. Not cleaning the pad often enough.
      Here's a list of the solutions in matching order,
      1. Shrink your work area down, the harder the paint the smaller the area you can work. The average area should be and average of about 16" by 16" up to 20" by 20" or so. You have to do some experimenting, (called a Test Spot), to find out how easy or how hard the defects are coming out of your car's paint system and then adjust your work area to the results of your Test Spot.
      2. For removing defects out of the paint you want to use what we call a Slow Arm Speed. It's really easy to move the polisher too quickly because the sound of the motor spinning fast has a psychological effect to for some reason want to make people move the polisher fast. Also the way most people think is that, "If I move the polisher quickly, I'll get done faster", but it doesn't work that way.
      3. When first starting out many people are scared of burning or swirling their paint, so they take the safe route of running the polisher at too low of a speed setting, again... this won't work. The action of the polisher is already g-e-n-t-l-e, you need the speed and specifically the pad rotating over the paint as well as the combination of time, (slow arm speed), together with the diminishing abrasives, the foam type, and the pressure to remove small particles of paint which is how your remove below surface defects like swirls or scratches. It's a leveling process that's somewhat difficult because the tool is safe/gentle while in most cases, modern clear coat paints are harder than traditional single stage paints and this makes them hard to work on. This is also why people get frustrated, they don't understand paint technology, all they know is their paint swirls easy and getting the swirls out is difficult and thus frustrating.
      4. For the same reason as stated in #3, people are scared, or perhaps a better word is apprehensive, to apply too much pressure and the result of too little pressure is no paint is removed thus no swirls are removed.
      5. Just the opposite of item #4, people think that by pushing harder on the polisher they can work faster and be more aggressive, but the truth is the clutch in the tool is a safety mechanism to prevent burning and will cause the pad to stop rotating, thus less cleaning or abrading action and once in a while this will lead a person to then post on the forum something like this, "Hey my pad doesn't rotate". There needs to be a balance of enough pressure to remove defects and keep the pad rotating but yet not too much pressure as to stop the rotating action. This balance is affected by a lot of things, things like type of chemical, some chemicals provide more lubrication and the pad will spin easier, curved surfaces or any raise in body lines will tend to stop the pad from rotating. This is where experience on how to address these areas comes into play or you do the best you can and move on. It's not a perfect tool, nor a perfect system, but it's almost always better than working/cleaning by hand.
      6. Applying pressure in such a way as to put too much pressure to one side of the pad will cause it to stop rotating and thus decrease cleaning ability.
      7. Too much product over lubricates the surface and this won't allow the diminishing abrasives to do their job plus it will increase the potential for messy splatter as well as cause pad saturation. Too little product will keep the pad from rotating due to no lubrication and there won't be enough diminishing abrasives to do any work. Again it's a balance that comes with experience, or another way of saying this would be it's a balance that comes with hours of buffing out a car to learn what to do and what not to do. Information like what you're reading here is just an edge to decrease your learning curve. Hope this is helping.
      8. Most people don't clean their pad often enough and most of the time the reason for this is because they don't know they're supposed to clean their pad often and they don't know how to clean their pad. Again, that's why this forum is here to help you with both of these things. You should clean your pad after every application of product or every other application of product, your choice, most of the time cleaning your pad after every other application of product works pretty well. It enables you to work clean and enables the foam pad, the polisher and the next application of fresh product too all work effectively. How to clean your pad will be addressed below sooner versus later, but not at the time of this posting. (Sorry, I'm behind a keyboard, not a video camera
      The first 4 are the most common. Can't tell you how many times we hear a comment like this from someone in the garage after demonstrating the correct technique
      "That's what I'm doing wrong"
      The dual action polisher is a gentle tool, that's why people like it. People are afraid of machines because they're worried they're going to either instill swirls or burn through the paint. When they learn that this is pretty hard to do with this machine, so after enough research or after watching a demonstration they learn to trust it and try it.
      Summary: People like the dual action polisher because it's oscillating action is safe and gentle to the surface.
      Now follow me on this...
      For the same reason people love the dual action polisher, (it's safe and gentle), a segment of people get frustrated with it because it won't remove all defects all the time. It won't tackle serious or deep defects quickly and easily. It won't always work on really hard paints. So for the same reason people love this tool, they also hate it, they just don't know why. Maybe after reading this post they will understand.
      This is the reason this thread is so widely read and you can learn a lot from it if you'll only take the time to read through it.
      PC + 83 not "Cutting" it! - The Limits of the Dual Action Polisher
      Even the pictures of the paint on the white truck on the first page and the story behind it are powerful and REAL (This writer took them and did the testing with both the G100/PC and the RB).
      When the G100/PC with a strong cleaner/polish like M83 and our W-8006 polishing pad doesn't remove the defects to your satisfaction or within an acceptable time limit the answer is not to get more aggressive with a more aggressive pad or chemical or both, the answer is to switch to a more powerful machine like the rotary buffer and or take the car to a Pro who knows how to use a rotary buffer, or learn to live with the defects.
      Hope this helps...
        Thank you very much Mike.. very helpful to me..
