Swirls in Black Paint from Scratch X
  • Swirls in Black Paint from Scratch X
    Looks like I've got a lot of swirls after using Scratch X on a Black car. I was trying to remove some water spots, by hand. What now?
    Re: Swirls in Black Paint from Scratch X
    Can you post pictures?
    What was your method/process?
    What did you apply the product with?
      I used a microfiber pad and just rubbed it on.
      It did remove some of the water spots. This was a friends car that was badly neglected, but this may be worse than it was.
        Did you wash and clay the car prior to using ScratchX to remove surface contaminants?
          I washed it but did not clay it.
            You may have not worked it in enough.
            By the way, Welcome to Meguiars Online!!
              First thing I would do is get yourself some foam applicators. They are gentler than the microfiber applicators.
              The second thing I would do is buy a bottle of SwirlX.
              I would then apply some SwirlX over the swirled area with a foam applicator.
              If that doesn't work, I would then re-apply ScratchX with a foam applicator.
              --Al Kimel
