Question with picture
  • Question with picture
    Hi there, 2000 Honda Civic here that was washed, clayed, and waxed with Zymol cleaner wax 2 weeks ago (before I went crazy and started this detailing frenzy on here). It hasn't been washed again since. Here are a couple pictures of the roof in bright sun.
    The close up one is a corp of the other. It's kind of hard to see, but it's more visible by the eye. There are a few white marks that kind of look like when a car's paint starts to oxidize, but they are only noticeable after I wax because the wax must fill them in and show white.
    Any ideas as to how to fix this or prevent it from happening again? Also, any thoughts on getting rid of the swirls? The Zymol obviously didn't do it, so where might I go in the Meguiar line for something more aggressive. Thanks guys!
    Re: Question with picture
    I'd suggest using some Swirl X first then if that doesn't work try Scratch X 2.0
    Take a look at this article on How to Remove Swirls By Hand
    Remove swirls my friends.
      Hopefully it isnt any clear coat failure.
      Definately give SwirlX a try.
        It's kind of hard to tell, since it's so small.
        I would try Some SwirlX or ScratchX 2.0 too
        Matt
          Thanks for the swirlx recommendations. I'm pretty sure it is in fact clear coat failure. I wouldn't be surprised really. It seems all Hondas get that eventually, especially since it is parked outside. Any recommendations on keeping it from getting worse? Basically just applying protective wax on a regular basis?
            Polish and wax.
              correct my civic has the same problem on the roof. i have like a quarter size spot.
              03' Honda Civic EX - 89,xxx mi.
