I have used my PC7424 numerous times on my BMW with great results. This weekend I used it on my 2002 white 4runner to remove discoloration and oxidation. After applying the items below, the paint has come out brilliant white. My problem is the shine is hazy and has less wet look or gloss than sections of the car I did not touch. I used the following items in order.
Meguiars Medium-cut cleaner #1 on a LC yellow pad
Meguiars Fine-cut cleaner #2 on a LC white polishing pad
Klasse All-in-One polish on a LC white polishing pad
Meguiars gold class liquid wax hand applied.
When applying the medium-cut cleaner, I worked in small sections and worked it in until it was dry completely dry, which caused some caking on the pad. What can I do to remedy what I have done? I'm in the market for new pads anyways, so maybe I used the wrong ones.
I only did the hood and fenders and will not do anymore until I can figure out why the parts I have worked on are not as glossy as the untouched sections.
Thanks for the help and suggestions
