proper way to wash 2.0 foam pads, foam applicators.
  • #31
    Re: proper way to wash 2.0 foam pads, foam applicators.
    Regular to Heavy Duty cycle generally is medium to high heat for 30 minutes or longer. We've seen them go for an hour on moderate heat without issue.
    How often do you guys use the products specially made for cleaning pads / MF towels ?? do you guys even use those products?!
    It'll be a bummer if I found out I don't need them, just ordered 70 dollars worth of pad cleaner+conditioners
    • #32
      Ah...sorry, but I have always used just Liquid Tide and Dawn Soap. They work great and I have never felt the need to use something else.
      Now that does not mean that the specialized products you just bought may not do a better job as it just may!! The first time you wash the pads, do one batch with Tide and the other with the specialized cleaners; then you can decide if it is worth it or not...
      • #33
        For buffing pads and applicators, I spray them down with Super Degreaser mixed 4:1. Take the hose and just spray them off. Cleans them quick and good. Spin them dry on the rotary while hitting them with some air from the compressor. Works great for me.
        • #34
          What you need to consider is that some of the degreaser could be left in/on the pads. If so, it's going to be mixed into whatever you are applying to the paint and stands a good chance of breaking it down.
          • #35
            Just as Tim has never used them, neither have we here at Meguiar's. Oh, and if you think we go through a lot of pads, you should see the number of microfiber towels we go through!!
            As for the products you ordered, many people have given such products very favorable reviews so you didn't really waste any money. Do your own test though - keep a group of towels that you only clean with those specialty products and another set you wash as we've instructed. If after several washes you find the specialty products to produce superior results, then stick with it. If not, then know you have the thanks of many forum members for conducting the test! It's what's usually called "taking one for the team".
            • #36
              I generally apply three to four applications of Dawn dishwashing liquid and warm water, scrub with my knuckles then wring gently by hand. I keep cleaning until the water doesn't discolor any longer.
              Brad Mower
              SLC, UT
              • #37
                Alright guys! I've tried the pad cleaner/ microfiber wash with a couple of dirty MF towels and a few used pads,
                the results are pretty nice! All I did was dunk it into the solution and squeeze the pads / rub the towels only a few times and I no longer feel the residue of waxes! (usually I still smell / feel the waxes after a wash in the laundry, maybe it's just me?)
                I washed them by hand so they are still being air dried right now.
                I gotta say the pad cleaning solution ( basically a powdered form mixed into water) cuts a lot of time if you plan on washing your pads/ MF towels by hand .
                Just hate the wait for air drying though.
                the product I used today is the Cobra Quik Clenz Foam & Wool Pad Cleaner. I'll tell you guys how the pads + MF towels feel after they're completely dried
