Need Quick Advice
  • Need Quick Advice
    Just wondering what I should do with the citation I am in. Yesterday, I did a quick detail and used DC1 and applied NXT 2.0 coat # 1..
    Today, It is cloudy and cool. its about 50 degree's out. I have the car parked in the garage. The car is very cool to the touch. Is it worth putting a coat of wax on when its that cold. I mean its pretty cool to touch. You know when you touch it. Rest of the week is looking in the low 50's. Do I shoot for another day.. but having to wash it again before I do it.
    What do you guys suggest?
    ______________________
    Tyler
    2002 Yellow Chevy Monte Carlo SS
    My Albums: http://s394.photobucket.com/albums/pp24/Johnson0667/
    Re: Need Quick Advice
    Shouldnt be a problem to do it now. 50's isnt that bad. You can pull it out to work on if you like, maybe catch a little sun to warm it up?
      The air temp is 50... the surface temp is what i was concern about.. or does the surface temp affect anything
      Tyler
        Yeah, it is mostly surface temp and humidity that matter.
          so I should prolly wait with the surface temp so cold?
          Tyler
            There isn't an issue with surface temp. 50 degrees is OK.
            Main thing is to let you wax dry before removing which may take a little longer due to the temp. Use thin coats and certainly use the swipe test before removing. If you have issues during removal, due to the temp, a QD spray of your choice will help aid in removal.
            Andy M.
            Andy M. Moderator
              Usually your okay if it is above 40 ish. If you have some sun, bring it out warm it up a little and apply your wax. Thin coats and remember it will probably take a little longer to dry.
