Grit Guard bucket
  • Grit Guard bucket
    Does anyone know where I can purchase a Grit Guard wash bucket? I have look anywhere locally, but it seems to be only available online. I think Meguairs does not sell one. Thanks!
    Re: Grit Guard bucket
    For now, you can only buy them online. I called the manufacturer several months ago, and while they are in negotiation to start selling the Grit Guard (there is no Grit Guard bucket, only the Grit Guard itself) in auto parts stores, there is currently no retail option.
      If you're referring to the actual bucket, it is just any 5 gallon bucket. I purchased mine at ACE Hardware.
      Colin
        To save money you can get grit guards at ads, or autogeek alone, and go to homedepot and get the (Homer buckets "orange ones") and it works perfectly. You will spend less then 20.00 for 2.
        '06 Honda Civic LX Coupe "Galaxy Gray"
          Like the above post said, do not get the buckets online, they're a rip off. Buy the grit guards online only and get the buckets yourself, it'll fit fine.
            I'd get the Grit Guard and then measure it, and then go buy your bucket, just to be safe. But yeah, any store should have some 5 gallon type that works.
              FWIW, I have read where some buckets taper towards the bottom and the Grit Guard doesn't go all the way to the bottom.
              The measure and check suggestion is a good one.
              Charles
              The Rainmaker
                may i ask why you want the grit gaurd bucket ? its literally the same bucket you would get at lowes or home depot with just a grit gaurd logo on the bucket...i ordered my grit gaurds from ADS..then went to lowes and spent 4 bucks for 5 gallon buckets
                Addicted
                  When buying to bucket, look straight down the sides. If it goes straight down then you are probably good. If you see it taper in, the guard will probably only go 3/4 the way down.
                    I had bad luck with lowes ones it didn't fit. Just bring your guards with you. So you wont be going store to store returning it because it wont fit.
                      really ? were they the gray ones ? these are the 5 gallon ones i got from lowes..they were 2 dollars for one and its perfect fit for the grit gaurd
                      Addicted
                        Wow when i was there they didn't have that one. they only had white no labels ones. wow it looks great because i have the orange ones from H.D. In color wise.lol
                          hmm thats weird..they usually keep them stocked all around the store..you will find a stack of them in the most random places
                          Addicted
                            I didn's seen them. Sux oh-well.
                              The Homer buckets with a snap on lead are less than $5. No one seems to be discounting the grit guards (manufacturer must be setting a floor price) except through the usual discount codes, etc.
                              Al
                              ~ Providing biased opinions
