General Auto Detailing Discussion. Participate in existing discussion or start a new thread with your question.
Would this apply to most glazes or just Meguiar's 07?
Most glazes...
Products just don't spread out very well at speeds lower than 3 and th 4.0 to 5.0 range makes move the pad with the product over the paint easy while keeping the pad oscillating for thorough working of the product over and into the paint to whatever level that's possible.
The 6.0 speed setting and even the 5.5 is really too fast and since you're not trying to remove defects you don't need speed.
i have to agree with mike, pure polishes like #7 have a lot of play time before they are really worked in..the oils in #7 and in most pure polishes do need the speed to get worked in more effectively and quickly..i usually use speed 4 but sometimes ill bump it to 5 if i want to get the job done quicker
thanks guys i appreciate the help I'll try it on speeds 4 -5 do you use Microfab cloth to take it off or use a softer faom pad then the one used to applicate?
