can i hear a few opinions on members that have used Megs05 and Megs07 with a PC and give me some feed back ...Im working on my 2nd car a 1991 Honda Civic light blue in color ...thanks MOL
A Little Help
Re: A Little Help
I do #7 in a small area at one time; say one panel. This prevents it from drying. It's difficult to remove when dry.
I apply #5 like a wax, letting it dry to a haze and then wiping it off; again one panel at a time. It is very easy to remove.
The power application will tend to make #7 difficult to remove if you over work it to the point where it gets tacky.
#5 wipes off after hazing extremely easily.
I personally wouldn't bother with power. You don't need power to rub it into the paint. Power will have you constantly juggling the buffer and a removal towel. It's also labor and time intensive with #5 as well.
Product on a foam applicator in one hand and a clean MF towel in the other for quick removal works best for me. Just too much time wasted with a DA.
You'll have to make that decision yourself. I just think a DA's a waste of time and not necessary. If your finish is prepared well enough to warrant either product, then a manual application is all that's necessary."If we knew what we were doing, it wouldn't be called research would it? (Albert Einstein 1879-1955)
BOB
