I'm a daily driver of a silver jeep 2005 and my SUV sits outside in a parking lot while i'm at work. after #105 and #205 i was thinking of using #7 then either 20 or 21 followed by NXT 2.0 liquid wax all with a PC7424xp which is the correct combo for keep the pop in yourcar daily. Know of course with this is with in reason i do drive it daily but still keep the pop till the next time when it time to wash and polish and wax again.
I'm a daily driver can i use which will product will help maintain the pop on my car
Re: I'm a daily driver can i use which will product will help maintain the pop on my
You don't really need to do the #20 or #21 before the NXT 2.0, but if you did want to use one, go with the M20, since #21 and NXT 2.0 are essentially the same thing, just that #21 can be bought in bulk and can be used with the rotary.Shane
21/nxt (Detailer Line/Retail Line) Same product.
I would say unless your removing some defects, you wont need to go through all those steps all the time. In between waxes I would use M135 or Ultimate Quik Detailer to maintain the "pop" and protection.
Originally posted by HighLine View Post105, 205, 21 Is Great, then maintain with M135 or Ultimate Quick Detailer
Good luck.quality creates its own demand
As far as waxing go, there are no "rules". M20, M21 and NXT are great waxes and I'll bet that you'll have amazing results.
Personally I like to work with M20, but that's me. Maybe you would like NXT more than the others, best thing to do is try for yourself and play
Keeping a couple MFs and bottle of QD or UQD and California duster in the trunk will help you keep it looking really good between sessions. Once I had my car where I wanted it, I spent 5-10 mins a day on maintaining it.
I usually wiped it down with the duster daily when I left for work in the morning and would usually give it a QD about every other day. I found that going that route not only kept my car looking its best, but it also made my detailing sessions easier because the car had been maintained.
Originally posted by HighLine View Post21/nxt (Detailer Line/Retail Line) Same product.
I would say unless your removing some defects, you wont need to go through all those steps all the time. In between waxes I would use M135 or Ultimate Quik Detailer to maintain the "pop" and protection.Nick
Originally posted by glenncontreras View Postso then #7 is out of the question then?
Try it and see what it does for you. It gets laid down before you wax, so you would probably use it 3-6 times a year depending on how often you need to wax your car.
M7 a pure polish that can help bring out the color and give a little more gloss by restoring some of the oils to your finish. The difference tends to be more pronounced on single stage finishes and darker colored cars. If you have some and give it a go, the worst thing that would happen is you would spend the time to lay it down and then wax it over and then decide the end result isn't worth the extra effort. It certainly won't hurt anything.
Check out this article: Your Daily Driver: A Simple Wash & Wax Regimen.
You may find that you will not notice any difference at all by using #7 on a silver car. No harm in trying it, of course. Perhaps you'll like it.
If I were in your shoes, I would stick to either M21 or NXT. I don't see any gain in using M21 as one's base and then topping it with NXT. But of course, there's no harm in trying different combinations. Why not use NXT as your base sealant and then top it with M21? Keep trying different combinations until you find the one that you prefer.
Do consider using UQW as a maintenance protectant between waxes. Have fun!Swirls hide in the black molecular depths, only waiting for the right time to emerge and destroy your sanity.
--Al Kimel
Originally posted by Murr1525 View PostFor a daily driver, you might like to get friendly with a product like ColorX or #66.
Tom
