Using Ryobi ERO 750VK Random Orbital buffer
  • Using Ryobi ERO 750VK Random Orbital buffer
    Hi guys ,
    I just bought a Ryobi Random Orbital Sander/polisher. I purchased the Meguiars soft buff pads.
    I have MANY swirl marks and light scratches on the red duco of my 2002 Mazda 323 Astina SP20. I used Meguiars Mirror Galze FINE CUT CELANER. I found after using this priduct with the Megs 7" 2.0 suft buff CUTTING PAD. I was still left with some deeper swirl and light scratches. I really do need some advice on the use of the orbital machines and recomendations on using other products to "cut" out the swirls and scratches still left behind !
    Your professional advice and recommendations are highly valued ,
    thank you,
    Martin
    Martin Sifredi
    Concours Automobile Presentation
    Re: Using Ryobi ERO 750VK Random Orbital buffer
    Because I know machines vary from country to country, a Ryobi orbital polisher in Australia could be a very different machine than what is sold in the States. Could you post a photo of your Ryobi and provide some specs? For instance, what are the speed settings and is speed measured in OPM's or RPM's?
      We see you've posted this question both here and in the thread where it seems all you Aussies were talking about this tool and others like it.
      What looks to be potentially your biggest issue here is the use of the cutting pad. We really don't recommend this pad with a dual action polisher because it is very aggressive and will likely haze the paint. Instead, try using the polishing pad with the tool set to a fairly high speed and use moderate downward pressure on it. If you can find some M83 Dual Action Cleaner Polish it might work better for you than the Fine Cut Cleaner. M80 Speed Glaze is another good option; although it has a bit less cutting ability it does contain more polishing oils.
      Lastly, if you have Ultimate Compound available in Australia it would really be our top choice for this application.
        Hi guys,
        Thank you for the response.. I am attaching the web links to the specs of the Ryobi RO unit.
        Specifications:
        Unique selling point: Lightweight one handed random
        orbital sander
        Power input: 750 Watt
        No load speed: 4000-7000 opm
        Pad size: 150mm
        Orbit size: 3.5mm
        Weight: 3 kg
        Units per pack: 3
        Units per pallet: 96
        Carton size: 495x170
        x305mm
        www ryobi.com.au/Assets/.../71da4103-59a1-48e1-9ad9-9ee44a3a3788.pdf
        www ryobi.com.au/.../641a9f89-e995-41f7-8b8c-b6db8ae071cc.pdf
        (Copy and paste into browser, add "." after WWW to access the PDF)
        ________________________________________________________________
        I am thinking of upgrading the RO unit to the AEG EX150E which has a dual setting for orbit offset and just a better quality unit.
        SPECS OF AEG EX150E below:
        AEG-EX150E
        AEG EX150E 440W 150mm Random Orbital Sander 240 Volt
        Features:
        Dual orbits for control of material removal
        Variable speed for optimum control
        Soft start and pad brake for a gouge free workpiece
        Through body sealed slide switch for reliability and ease of use
        Convenient hook and loop paper fastening
        Dust extraction, with dust bag or absorption system
        Diecast construction for strength and durability
        PRODUCT SPECIFICATION
        Power input: 440 watt
        No load speed: 4000-10,000 rpm
        Oscillation rate: 8000-20,000 rpm
        Oscillation diameter: 3.2/6.4 mm
        Sanding disc size: 150 mm
        240 volts
        Net Weight: 2.8 kg
        Shipping Weight: 3kg
        Last edited by Markus Kleis; May 18, 2010, 05:57 PM. Reason: No hyperlinks before 30 posts
        Martin Sifredi
          Judging by the specs alone, I'm not sure if the AEG is an upgrade over the Ryobi. It's got a small motor, but geared for a much higher speed (meaning smaller orbits). This may work better for fine finishing sanding, but not detailing.
          I'd imagine the Ryobi is very similar to the popular Porter Cable here in North America, in terms of orbit size (and therefore paint correction effectiveness). It has more power, and thus can work at a slightly faster rate. Stick with it and experiment with pad and compound choice.
            Hi mate, a bit OT but from NZ here and I'm thinking about buying the same Ryobi tool. However what I'm not really clear about is whether I need anything else to mount this pad here for example http://meguiarsdirect.com/detail/MEG+W7207.
            Do I need backing plate etc. etc.?
              No you dont. I have ordered some Hex Logic Chemical Guys pads (www. chemguys.com.au/Auto_Detail_Polishing_Pads_For_Rotary_And_DA_Polishers_s/42.htm. I am going to use the Green with Meguiars Ultimate Compound, then White with Ultimate Compound or Megs Finishing Polish, and apply wax or sealant with the Blue one.
              I have also just bought the Ryobi ERO750. Some people have mentioned it works well. Were you maybe polishing too fast ? I think the Megs Finish Glaze is the wrong product for correction. Its Clear Ultimate Compound is the correct one to use. Also made to use by hand with good results, no reason why a machine like this should not help.
              Last edited by Markus Kleis; Jun 7, 2010, 02:52 AM. Reason: No hyperlinks before 30 posts
                Sorry for the thread revival, but would the G110v2 be 'better' or similar to this Ryobi ERO750 in terms of polishing/waxxing/cutting "Potential"? i.e. would there be a great difference between the 2 D/A's for general detailing?
                '69 Dodge Charger 'General Lee' (Smith Brothers Restoration)
                '00 White R34 GT-R V-Spec
                '04 Blacked-Out E55 AMG
                '03 Blacked-Out H2 Hummer
                '09 Blacked-Out ML63 AMG... + more
                  While the Ryobi ERO750 will certainly work, we aren't 100% sure if it will allow you to apply as much pressure before bogging down as more traditional D/A polishers used for automotive paint polishing do. This does seem to be a pretty popular tool in Australia and New Zealand where our tool and the PC can be difficult to source.
