For best result ?
  • For best result ?
    hI,
    1) IF I WILL USE GOLD CLASS CARNAUBA PLUS WAX OR NXT GENERATION TECH WAX 2.0 I DONT NEED TO USE A PURE OR CLEANER POLISH ?? BECAUSE ALL READY THEY INCLUDE POLISH ?? RIGHT?
    2) FOR BEST RESULTS ..... PURE POLISH + PURE WAX.
    OR
    CLEANER POLISH+ PURE WAX
    OR
    AFTER THE SURFACE IS DETAILED
    JUST USE NXT GENERATION TECH WAX 2.0
    ADVICE PLS.
    Re: For best result ?
    I would recomend to use either ColorX + Nxt or Gold Class, or the Cleaner/Wax + Nxt or Gold Class.
    If possible, claying would be good to.
    1. Wash
    2. Clay
    3. Cleaner/Wax or ColorX
    4. Gold Class or Nxt
      thanks man...
        A Cleaner/Polish, is a product that does this, has some cleaning agents (abrasives) and some polishing oils. Just as you use a Paint Cleaner you can use a Cleaner/Polish to remove swirls and paint defects. Really depends on what you are working on, a Cleaner/Polish can be beneficial.
        A Pure Polish is a product that contains no abrasives, but it does provide high amount of oils, resulting a surface with high gloss but more noticeable on dark colors vehicles. This is a optional step, depends on your goals and level of satisfaction. On some situations this can be highly beneficial.
        Pure Waxes are only dedicated for protection, they do not have abrasives nor polishes.
        Polish Waxes have some polishes in them and offer protection but the grade, amount of polish you'll find in them is not near of a dedicated product like a Pure Polish.
        OR
        OR
        ADVICE PLS.
        Is depends on what are you working on and trying to accomplish. A combination like Pure Polish + Pure Wax won't remove any defects at all, so basically if you have a very neglected finish this won't be the right process.
        A Cleaner/Polish + Pure Wax will (depending on how aggressive the Cleaner/Polish is) remove certain amount of paint defects "leaving behind" polishing oils for gloss and with the pure wax you'll just protect the finish.
        So basically for the best results you would want to do this
        Meguiar's 5-Step Paint Care Cycle - Updated!
        Hm! Don't know why I just didn't provide you with this link
