Glossy Black Trim BMW 5 series
  • Glossy Black Trim BMW 5 series
    How do you clean and maintain glossy black trim? I am assuming it's plastic and very shiny.
    2011 BMW 535i
    2011 335i M Sport Coupe
    2011 535i Sport
    2009 Genesis Sedan 4.6
    Re: Glossy Black Trim BMW 5 series
    I just cleaner/wax and wax it on my car.
    Have never tried to correct it before.
      I thought putting wax on unpainted plastic was counterproductive?
      2011 535i Sport
        It is the flat/textured plastic/paint that cant have wax.
        Anything smooth/glossy can be waxed, like glossy paint, glossy plastic, metal, etc.
          That plastic has clear coat on it. Simply use a standard polish that you would on the paint, then wax them.
          Matt
            I believe it is clear-coated. If it is the same surface I am thinking of, it can be treated like paint. It is certainly not a porous, dull plastic.
              Yeah you can see your reflection in it. It's smooth and glass like. Can you clay this surface as well?
              2011 535i Sport
                I presume you can clay it, but I can recommend the Ultimate Quck Wax .. you'll be amazed, for sure.
                  Yup, can be clayed.
                    I would treat it the same way as paint.
                      I just finished up a 328i with this trim. I used 205 on a yellow pad and it turned out great.
                      Just my $.02
                      Never take life seriously. Nobody gets out alive anyway.
                        Great Information!!!
                        My C Class has this identical black glossy plastic, and it has some swirls!
                        I suppose I could try a light hand application of UC and see what happens?
                        I can't believe I never thought to wax it before! Stupid me.
                          I use M205 of anything above cleaner wax. M205 actually works very well for polishing that type of surface in my experience.
                          UC might be a little too aggressive - but if you try it by hand with minimal pressure it might be OK.
                            Just my $.02
                            Is 205 similar to swirlX?
                            2011 535i Sport
                              TJPark01, I like the avatar
                              Remove swirls my friends.
