New DA Approved M105
  • New DA Approved M105
    I've been seeing the new DA approved version of the M105 online and i was wondering if there really is a difference between it and the pre existing M105. Has the product been reformulated or is it just a way to attract more people to purchase it?
    Re: New DA Approved M105
    It is more DA friendly, though Ultimate Compound may be the closest/most DA friendly product.
      What would make it more DA friendly?
        I cannot speak to the reason "why" it is different. I can tell you when buying the stuff, I could only get the "DA friendly" version, there was not an option for either one or the other.
        I worked on some panels recently and nothing out of the ordinary or not somthing that I have read about when using a Rotary with the stuff was any different.
          More 'friendly' would mean things like lower dusting, more work time.
            Ok thanks. That makes sense. So it would work more like the Ultimate Compound?
              #105 will be stronger.
              But the UC would be easier for 'general strong cleaner' needs.
                Yes the 105 has more cutting ability. I've used both products and love them both
                  I used the original formula with the d/a, and the more d/a friendly version. I can tell you there is more work time and a lot less dusting, with the d/a approved version.
                    How do you tell if it's the d/a approved version?
                      Probably says so on the bottle (back).
                      -HealthyCivic
                      Check out the glossary
                        Old version of M105 - recommended use via hand and rotary.
                        My personal findings is that the newer DA friendly will have much longer working time (wetter) and in terms of aggressiveness, I don't see any significant difference between the old and the new. Plus when its a little bit wetter, it dust lesser then the first gen. of M105.
                        Hope that helps.
