People who have been using the new Microfiber system...how much of the compound do you find you use for a full vehicle? I am purchasing the system soon and just trying to decide on what size I want to go with. Thanks!
MF system product usage
Re: MF system product usage
Very little! You only need 2-3 pea sized drops per section once the pad is primed. If you're just doing your own car the 16oz bottle should last you a while. If you plan to do several cars, the 32oz size would be a little better. I've had my 32oz bottle since December 1st and it's just about gone now.
Nick Winn
Irvine, CA
nawinn@meguiars.com
Originally posted by Marine Toys View PostSo what is the best way to prime the MF
Apply a very small amount on the entire surface of the MF disc. You can apply a few lines of product then slowly run the DA on the paint. Look at the disc. See where product is not on the disc and apply product in those areas so the entire surface of the disc has product on it. that's it. The disc is primed.
Clean the disc with compressed air, or in my case I use a dry "Bug Sponge", between each section pass. Apply a few pea size amounts and continue.
