How do you clean you microfibers foam pads and microfiber wash mitts ? I hand wash everything i got a supreme shine 2 other microfibers and megs foam and simoniz Terry applicators and a simonz wash mitt I need some tips
Cleaning microfiber towels and wash mitts
Re: Cleaning microfiber towels and wash mitts
You can put microfiber pads, towels and discs in your washer. Just wash microfiber products separately on low temperature with liquid detergent (no fabric softener, no bleach). If needed to add some plush use one cup of distilled white vinegar with a final rinse.
You can use a dryer (tumble air dry setting is the best) or use a drying rack.
All microfiber items (polishing towels, waffle weave drying towels, wash mitts, applicators) can go into the washer together using any laundry detergent and warm water, then into the dryer on low heat only. Foam pads can go in with microfiber items if you wish.
Terry cloth towels should be washed separately as they will shed lint which the microfibers will catch and hold onto.Michael Stoops
Originally posted by Michael Stoops View PostAll microfiber items (polishing towels, waffle weave drying towels, wash mitts, applicators) can go into the washer together using any laundry detergent and warm water, then into the dryer on low heat only. Foam pads can go in with microfiber items if you wish.
I just ran mine yesterday. All my Micro Fibers, Water Magnets. I stop short on MF pads for wax as I might just get a new batch.
Warm/Cold
Gain Detergent
LOW heat, Delicate
Check in 15-20 mins
Looked mint.
I had some MF that became house hold towels and it got tossed in a different load, it was quite funny having to pull my regular clothing off the MF like it was velco.
