Diamond cut Vs Ultimate Compound
  • Diamond cut Vs Ultimate Compound
    witch one has more cut uc or diamond cut
    Re: Diamond cut Vs Ultimate Compound
    Not sure, but #85 is rotary only...
      can you use it with a d/a g110 because the megs rep i went to to buy some stuff had like half a bottle of 85 he gave it to me for free but all i have is a g110 so if its rotory only how can i use it i have a orbital buffer 2 will that work ?
        Ehh...
        It might work, it might not. Cant assure you of anything on that one.
          it turns out its not 85 its 4 meduim cut cleaner but still needs a rotory so no idea what i can do with it maybe lights with my 4 inch high cut pad
            #4 isnt bad for glass.
              yeah so if i use it on glass and head lights would it work with my g110 and a high cut pad
                Most headlights are plastic, so I wouldnt be using it for that.
                Its pretty good just by hand on glass. Probably wouldnt need to strong of a pad if used by machine. Remember it wont be removing scratches, just getting gunk off if needed.
