Unigrit sanding disc backing plate?
  • Unigrit sanding disc backing plate?
    I have a backing plate that I use for the Megs 4 inch foam buffing pads.
    Can I use this same plate with the unigrit 3 inch sanding disc?
    Thank you.
    Re: Unigrit sanding disc backing plate?
    If you mean S3BP then the answer is yes.
    W63 also works with 4" spot buffing pads but it's rotary use only.
