i have a megs cutting pad for my g110 is it ok to use speed 6 with that pad if im having a really hard time removing defects or to use with my #4 that says rotary only because i don't own a rotary
Speed 6 ??
Re: Speed 6 ??
Originally posted by OldSchoolDude View Post
it gives you less work time being it dries the product too fast.
There's a lot of variables here. I've had great results using speeds 5-6, along with moderate downward pressure. Whether or not the product dries too fast, I remove moderate defects in less time, versus using speeds 4-5 with less downward pressure.
If you have problems with product drying out with a PC, whats going to happen when you use a rotary? I'm sure you are aware that a rotary generates much more friction than a PC right? Friction = heat.
If you're having problems with product drying out, you may want to adjust your technique. I have never, ever had a backing plate lose it's grip.
Like a said, there are an awful lot of variables involved when polishing paint.
Re: Speed 6 ??
Originally posted by Jim Bob View PostI've used speed 6 on my PC with no ill effects.
Especially with the microfiber pads it actually will produce less favorable results and even ruin the pads. Meguiar's (who designed the G110 and G110v2, as well as the pads and polishes in question) did not design them to be used at speed 6... so I highly recommend sticking to the directions coming from the creators of the products for best results.
Re: Speed 6 ??
I don't drink and drive. Drinking and driving can create a load of problems. When I use speed 6, I am removing more severe defects. I even use a 4'' light cutting pad for maximum pressure per square inch, as well as maximum Oscillation/rotation.
Your drinking and driving analogy is irrelevant, because when I use speed 6, I am actually accomplishing defect removal. What do you accomplish when drinking and driving?
I don't use the microfiber pad system, and am not planning to in the near future, so no problem there. There is no mention of "polish" in this thread, so, unless you're referring to a specific polish, (cleaner or compound in Meguiars terminology) you're just theorizing, which is ok, you can disagree with someone, which again is ok, but do it tactfully, please.
I've been doing this for over 20 years, yet you insinuate that my skill level is on par with "drinking and driving"?
Have a nice day.
Re: Speed 6 ??
I have been using a rotary for over 30 years, it's what I grew up using.
When I use my rotary I use a product made for using a rotary which aids in the product from dry out.
Now I use my PC, total different ball game here, mostly because I use foam pads instead of wool.
I've seen pics of pads and backing plates completely wore out from using too high of a setting for a long period of time.
When I correct paint I'm not looking for speed but instead good results.
Speed 4-5 works best for me, if 6 works for others and have no problems than I say use it.
Just not for me in paint correction.Chief Engineer.
My part time job is to maintain my black Toyota!
Re: Speed 6 ??
I think that is a key point. Too high a speed, with too much downward pressure, for too long of a period can and will overheat a foam pad. It also depends upon what polish is being used. I used to use XMT 5-6 years ago, and never had any problems with overheating my pads. Lately, I have been using The Menzerna line of polishes. Menzerna is designed to be used with both Rotary and random orbit polishing machines, although we all know that a random orbit will only correct so much.
Like I said, there are an awful lot of variables.
