can you use 105 as a compound and polish beause i just got have only tryed it on a small panel i made and painted that had swirls and a few deep scratches and after i was done it looked perfect i used 82 after just in case but ive read on here it can be used alone is that true if the finsh isnt too bad ? then wax after
105 as a 1 step ?
Re: 105 as a 1 step ?
If M105 finished LSP ready and you're satisfied with the results then there's no need for extra polishing step and you can just protect the paint with your favorite wax/ sealant.
Most waxes/ sealants have some polishing oils in them anyway.
It really depends on how much it was worked on and after cleaning and inspection it tends to need a little more polishing. Thats why there is 205 but again depends on your satisfaction and how much it was worked in.
When I use 105 its on a Rotary so it tend to still need to follow up with 205.
