Rubbing Compound(RC) & Polishing Compound(PC)
  • Rubbing Compound(RC) & Polishing Compound(PC)
    1)Need some info on how and when to apply above two products?
    2)Is RC similar to ultimate compound and PC similar to #7,#205 or ultimate polish?
    Re: Rubbing Compound(RC) & Polishing Compound(PC)
    A bit more like #83 and #80 I suppose, but not exactly.
    One is the mild cleaner (PC), and one the strong cleaner (RC). There is no set time when to use them.
    Generally speaking, you would do a test spot with the mild cleaner, and check results. If you need stronger, then go to the stronger product.
