How UQD/UQW works?
  • How UQD/UQW works?
    I've been wondering for awhile now if my thought process on UQD and UQW is correct.
    With UQD I assume that, when being used properly, it is a lubricant that removes light surface contamination. Also it leaves behind a trace of hydrophobic protection. This protection- is it something in the UQD that bonds to the existing LSP (in my case, ULW) or is it another light layer on top of the LSP?
    UQW, I'm assuming, is just adding another layer on top of the LSP. But does it also, perhaps, fill in imperfections in the LSP, and bond to it? Or, like I stated before, is it just another layer?
    Wondering if the mechanics of UDQ/UQW and their relationship with a LSP can be explained to me. Thanks!
    Mark
    Re: How UQD/UQW works?
    Well, Mark, both products contain hydrophobic polymers so both will bond not only to themselves (which is part of what the cross linking in a polymer is all about) as well as to the surface they're being applied to. But keep in mind that the polymer content in UQD is quite limited so it's not going to last long or offer a lot of protection. Yes, it will bead water like crazy for a while, but it is a quick detailer and not a wax of any sort. UQW on the other hand is very durable for a spray wax. It actually contains a blend of carnauba and polymer and it is actually quite good at hiding minor surface defects. We still don't consider it to be a substitute for a proper wax application (liquid or paste) but when used regularly - like at every wash - it can definitely prolong the protection on your paint.
      Awesome, thanks Michael.
      I wanted to know what was happening at a microscopic leek when I used these fantastic products. You nailed it!
