Polishing thin paint
  • Polishing thin paint
    Hi all,been away for awhile,it's good to be back.I'm looking for some advice if possible.I will be working on an older car that has quite thin original paint(Metallic),so i don't really want to remove any material when polishing.I have experience with M7,(i love the stuff) and M81 and i was thinking about using M81 via the DA to improve gloss and also fill any defects,rather than any correction work.Do you think this is the way to go? or should i infact do a gentle polishing using say M82 first?
    Re: Polishing thin paint
    If real thin, you may want to go by hand. Those products would be good, something with a mild cleaner wouldnt hurt like the Ult Polish, M82, applied gently of course.
      Is this a single stage paint your working with?
        Thankyou for your repliesRedifined,it's an older Metallic paint finish,1985 PPG i believe.I'll need to have a look at the Ultimate Polish,sounds very good.I think that my main objective would be hiding the light marring that's in the paint,rather than trying to remove it,so i really want something that can be used on a frequent basis,before topping with M16.Does the Ultimate Polish have a filling effect,or should i stick to M81/7.
          The wax would probably hide more than the polish. But since #7 has the most polishing oils, it would likely hide more the most for a polish.
            If you know the paint to be very thin and you're happy with a fair bit of filling, then a little M82 on a finishing pad, used lightly, followed by multiple hand applications of M07 and then wax is probably the best way to go. As long as you're easy on the M82 with a finishing pad, and you stay off high spots, sharp body lines, etc you'll be taking off almost nothing paint wise, mostly just rounding off corners of light swirls.
