Anything you can spray on the inside of wheels to PREVENT brake dust from sticking?
  • Anything you can spray on the inside of wheels to PREVENT brake dust from sticking?
    I spent a few hours cleaning the inside of these old Mercedes wheels. Is there anything you can spray on that would prevent brake dust from sticking? I used Ultimate on the smooth areas but you can't apply that in the intricate places.
    Re: Anything you can spray on the inside of wheels to PREVENT brake dust from stickin
    Looks like a perfect candidate for Meguiar's new for 2012 Hot Wheels Brake Dust Barrier in aerosol form:
    Auto Detailing Solutions has the 9oz cans available for $8.99 each.
      First I've seen it. Will have to try it.
        you can put wax also but im sure the ^^^^ product will work better. just want sure the wheel is clean when you coat it
          Remember to use a milder soap after putting a coating on, dont want to use the dedicated wheel type cleaners, which will be harder on the coatings.
            That wheel looks great. Can you explain your process/products briefly? I have tried to clean the inside of my wheels and have never been able to even come close to that.
              Used a blasting cabinet with walnut shells.
                #1 try it out.
                Waxes don't last long on wheels, not only because of all the brake dust and road contaminants but heat generated by the brakes. I would try a synthetic sealant or a coating on the inside of a wheel.
                  Originally posted by inyadreems View Post
                  #1 try it out.
                  You must be doing some major braking for the wheels themselves to get hot. The heat of the engine underneath, and the rays of the sun above on a 100F day will get a black hood hotter than any wheel should get.
                    It is combination of all the elements that will deteriorate the wax. I would go with a wax, sealant or coating geared specifically for wheels or a wax/sealant know to stand up to harsh elements like Collonite or Duragloss. Do an experiment and put a different wax or sealant on each wheel and see how long it lasts.
                      Opti-Coat, or one of the nano-coatings (CQuartz, AQuartz, etc) would be the best choices.
                      Francis
