NXT 2.0 turned into water?
  • NXT 2.0 turned into water?
    I think the wax just went hydrophobic on itself. Anyways, it finally got warmer where I lived and I gave my car a good washing and claying, but when it came time for the wax, shook the bottle a couple of times, then water got on my foam pad. Is it possible that the wax went hydrophobic on itself over the winter while I wasn't washing and waxing? And is the part that didn't become water still good for use?
    Toyota Corolla S ZZE136L
    After using UC, UP, and UW... I'm not happy with smooth as glass.
    Smooth as Glass is an old standard, the new standard for paint texture is Meguiar's Ultimate Quality...
    Re: NXT 2.0 turned into water?
    Try to give your NxT sealant several shake-up sessions to see if it mixes back. It got seperated.
      You can try placing the bottle in some warm water and then shaking it vigorously for 3-5 minutes. If it doesn't mix back, I wouldn't use it.
        This line was good for a laugh at a time when a good laugh was needed, so thanks for that!!!
        It sounds as though the product was damaged due to temperature extremes over time. If you can't shake it back together then it is bad and shouldn't be used. It won't hurt anything if you do use it, but it may not perform up to your expectations.
        Our products usually have a shelf life of 3 to 5 years unless they are exposed to temperature extremes for a period of time.
