Cutting Pad vs Polishing Pad & DA
  • Cutting Pad vs Polishing Pad & DA
    When using the DA will I get a little more "cutting" action using DACP #83 on a red Cutting pad versus the yellow Polishing Pad??
    Check this post out...
    Meguiars suggests not using it with a PC but check the post out.
    Brandon
    2007 Black Chevy Avalanche
    My Albums: Avalanche
      I've used the maroon cutting pad and DACP several times for deeper scratches and swirls. I followed up with DACP and a polishing pad. This was on my black Hemi. No problems.
      Tom
        I to have used the cutting pad with the da. Tried it a while back on my sisters car. I had good results but as eveyone has said, using it is taking a step backwards. After I went over her entire car, the paint did not look good. However following with 83 on a 8006 pad brought the finish back and the deeper scratches I was going after were gone. It can work well you just need to be cautious.
