Just had a thought of using some of my glass cleaner (the Detailer Line concentrate diluted at regular 10:1) to fill my windshield washer fluid since its so economical and my gallon lasts forever. However, I was curious if there's enough alcohol in it a 10:1 to keep it from freezing over the winter months and causing the reservoir to crack. It will rarely get below 20 here, but just thought I'd check and see if anyone else has ever used this, and if so, what the results were like. Thanks in advance.
Will Glass Cleaner freeze?
Re: Will Glass Cleaner freeze?
I can't address D-120 exactly, but I did have some washer fluids that had alcohol in it and it would 'slush' on some of the colder days. Even though the car(s) were garaged at night, just siting out while at work seemed just cold enough to chill it down.
Oh, yes I am referring to Seattle winters (actually Snohomish County).
Bill
Cool, thanks for the advice guys. I guess I've probably found enough uses for it anyway, but i thought why not try one more. Your advice will save me from having a dirty window in December driving over the passes and stuck with no windshield cleaner cause its all frozen!
washer fluid is cheap anyways
I have a gallon of Megs glass cleaner concentrate as well....I was thinking of buying a bunch of spray bottles and selling to my friends"STRIFE" aka Phil
Originally posted by STRIFE View Postwasher fluid is cheap anyways
I have a gallon of Megs glass cleaner concentrate as well....I was thinking of buying a bunch of spray bottles and selling to my friends2010 Subaru Legacy GT - Graphite Gray Metallic
