2013 Malibu 2SA dash. Leather or vinyl?
Re: 2013 Malibu 2SA dash. Leather or vinyl?
I would say it most likely is vinyl. Chevy has improved, but I would be really surprised if the equipped the dashboard with real leather. This really shouldn't affect the treatment much as I am quite certain that the leather is coated in this car, meaning that the leather is actually covered by a thin plastic like protectant. What ever leather/vinyl treatment you have been using on other leathers will work fine.
Of course check to make sure its coated or vinyl first, before using an aggressive cleaner not suited for bare leather. (Though the dash is most likely coated leather at the least.) To do this sprinkle a little water on it and see if it absorbs into the material. If it does and changes the color of the leather (meaning it was absorbed by the leather) it is not coated, and should be treated with very gentle cleaners and conditioned regularly. I highly doubt it is uncoated, just sharing a bit of advise.
To sum up, just do what you typically do cleaning the other leather/vinyl surfaces of the car with whatever product has worked for you.
Hope I helped!
Griffith Hawk
