removing remnants of window sticker
  • removing remnants of window sticker
    I need to remove the remnants of two stickers from the inside of my windshield. Recommendations for technique or product?
    Art Layton
    2009 Jetta TDI
    Razorbade and glass cleaner with some patience
      Re: removing remnants of window sticker
      3M adhesive remover or Goo Gone is another option.
        Goo Gone is the way..
          Also, if you heat up the glass from the other side with heat gun (maybe hair dryer too) then use a flat razor blade you can get most of the sticker off then use those chemicals mentioned to remove the glue residue. Ive ecen done this delicately on tinted windows, very delicately
            Thanks to all respondents; wanted to make sure there wasn't a technique or product I was missing.
            Art Layton
            2009 Jetta TDI
              Yes, I use goo gone, but only a small dab, as that stuff has a potent citrus smell.. So don't go crazy with it. just rub some in on the glue residue, give it a minute to do its stuff as in break it down, rub it some more, then with a cloth or garage towel rub it out.. Then use some glass polish.
                I use WD-40, but I didn't tell you that. ;-)
                Obviously, you need to use glass cleaner after regardless.
