1st time with Ultimate Polish and 5" pads
  • 1st time with Ultimate Polish and 5" pads
    I had a nice long review typed up, but then I accidently hit some button and it all went away
    Anyhow, long story short, I found that the Ultimate Polish has an insane amount of working time and an even more insane ability to spread across the panel you're working, allowing you to work a larger area with less polish. The 5" pads were great and considering I polished all 3 horizontal sections (hood, roof, trunk) with the hood being the only part clear coated, I only had to clean on the fly once. The roof and the trunk were both corrected after using 6 cross-hatch passes (6 times up and down / 6 times left and right) and wiping the polish off. I couldn't tell on the roof, the angle was too steep, but on the trunk, there were only a few RIDS (that had been seriously faded) and a bird etching that had also been diminished.
    The hood was the toughie, I used the same method as on the other 2 panels, but when I wiped off the polish, there were still lots of RIDS and swirls ... but it WAS really shiny and glossy. So taking the easiest route, I just hit the hood a second time with the UP and there it was, a swirl and RIDS free panel.
    Next came the wax, Ultimate Pate Wax. I used the 7.5" foam pad that I had cut down to apply the wax, using a butter knife to spread it on the pad in little slivers, while I didn't use much wax, it SEEMED like it took an awful lot of those slivers to get the pad primed. I applied it on a speed of '1' and the wax spread like hot butter. I waxed all three panels then removed it with a new microfiber cloth. I have to say it came off EASIER than when I applied it by hand and I think that I put it on thicker with the buffer.
    Anyhow, I have to say that the 5" pads and UP is definitely a winning combination, I'm glad I let you guys talk me into the 5 inchers.
    Don
    12/27/2015
    "Darth Camaro"
    2013 Camaro ... triple black
    323 hp V6, 6 speed manual
    Re: 1st time with Ultimate Polish and 5" pads
    Is it safe to assume you're talking about our new 5" Thin Foam Discs? Yep, they are getting rave reviews all over the place because, well, they're pretty fantastic!! Glad the Ultimate Polish worked so well for you, too!
      Yes, those are the ones. I asked all over the forums that I'm on and the Megs new thin foam discs were almost always included in the other opinions and I'm pretty much a Meguiars guy, so why not keep it all in the family. One of the things I like about them compared to my old pads is how easy they are to clean (although the wife still won't let me use the washer for them) ... a few spritzes of a mild APC a little agitating and hit it with a strong stream from the garden hose until the water runs clear. You can even "wring" them out - so to speak to get the excess water out for drying.
      I also discovered that UP has an insane working time and an even more insane amount of spreading ability. I started off by dividing my hood into quarters and soon discovered that in spite of only prepping the pad with a thin "X" there was more than enough polish in the pad to complete the entire half hood.
      I had found that highly popular YouTube guy and watched his videos and it reminded me of the 14 years of (arms speed too fast, too much pressure on the buffer, he reminded me about 'kissing the finish to spread the polish etc) bad habits I needed to unlearn, so following his advice and using the Megs products I ended up with some awesome results.. Really burns my biscuits that I can't post pics ... stupid electronics and their different languages.
      I saw the hood in full noon sun today and while there are a few deeper swirls (I probably could have used UC on the hood) left, it is 100 percent better than it was.
      Don
      12/27/2015
      "Darth Camaro"
        Glad to hear you like them. I knew you would and that's why I recommended them to you.
          Sounds promising! I attended the Good-Guys/Meguiars Del Mar Nationals last weekend which was a calculated mistake, because I knew that Meguiars would probably be selling their new MT 300 polisher. They were and although I resisted until the last possible minute, I couldn't leave without purchasing the show bundle Meguiars put together for the event. MT 300, 3 pads, and a backing plate. Now I have this polisher and new pads and a swirled up 2002 Subaru Outback just begging for my first detail action of the season.
