Having a quick look around I came across a PC 7346SP in stock at Lowes. It appears to be similar to the PC 7424XP. I will probably go with this or it's equivalent.
Specs from PC website -
Porter Cable 7346SP
6" Variable-Speed Random Orbit Sander with Polishing Pad
The 7346SP includes Polishing pad, PSA Pad, Sanding disc, Side handle, Wrench.
4.5 Amp, AC Only
Electronic variable-speed dial 2,500-6,800 OPM
Random orbit, swirl-free sanding/polishing action
Includes 6" proprietary counter balance for use with 6" sanding/polishing pad
Accepts 5/16 - 24 spindle thread accessories
Compact lightweight design - 6 lbs
100% ball and roller bearing construction
I am attempting to remove or lessen to some degree old Tree Sap Etchings on a black '05 Hyundai Sonata. As well as clean up swirls and minor scratches.
Considering the task please advise me as to -
- Is the PC 7346SP in fact equivalent to the 7424XP ?
- Which Backing Plate and size should I go with ?
- Which types/sizes of Pad(s) should I go with ?
- Which Product(s) should I go with ?
- What speed(s) for which product/stage of process ?
I have both 105 and UC, as well as Mags polish and wax. From what I've read here this will be a multi step process, what is the proper order to follow ? And bare in mind I am a novice as this will be my first time. However I do have an old '97 Nissan I will work on first.
Thank you....
Porter Cable 7346SP
4.5 Amp, AC Only
Thank you....
