Best Megs Products to Clean my Hottub
  • Best Megs Products to Clean my Hottub
    Hi Guys, I have an array of Megs products. Can I simply apply the same logic on my spa?. Clay the spa, followed by using my DA applying Ultimate Polish, followed by Ultimate Wax?
    Many Thanks,
    Rappy
    Re: Best Megs Products to Clean my Hottub
    Depends on what the hot tub is made of. Some are wood, or plastic, or fiberglass. Unless it is clear coated/painted, and loaded on a flat car and trained across the country, I would not use any of the products you mention, especially a DA. (maybe with the exception of Ultimate Wax by hand). Let's assume it is fiberglass (most are these days), I would use a soft scrub made especially for fiberglass spas. bathrooms, tub surrounds, hot tubs,etc. and do it by hand. You don't want to dull up the shine on the fiberglass. You could put on a coat of Ultimate Wax, but why? It won't hurt but again why waste it? I have been tempted to wax the walls in my showers so the water runs off nicely after showers, but not a hot tub, it is fulled all the time, and covered most of the time. It is a hot tub, not a clear coated, painted car. The two are maintained differently. Go to a spa/bath shop and get the proper products. "The right tool for the right job".
      When drained , in the seating areas, there are fine scratches.
      It is a fibreglass hot tub. In the past on baths & shower trays, I have used many Megs products, with great results!!!.
      And as you mentioned the tub sits in water, hence the question.
      Maybe I should look at using Plast-X instead or simply ultimate polish to remove the scratches.
        Edit. Tub is granitex/ ultralife.
