Polish
  • Polish
    Hi Is Wet look polish/wax or ColorX safe to use constantly, or are they just ment to use once.
    Thanks Shane.
    Re: Polish
    ColorX has been described as "Cleaner Wax on Steroids" and the cleaner wax is safe for continual use, I'm not familiar with 'Wet Look.'
    Don
    12/27/2015
    "Darth Camaro"
    2013 Camaro ... triple black
    323 hp V6, 6 speed manual
      Re: Polish
      A12 cleaner wax is sold in Australia under the name 'deep crystal wet look cleaner wax'. It is safe to use regularly (I do), apply gently like a regular wax and it will clean stains etc without cutting. Color x is more aggressive but still very gentle and safe for regular use.
        Re: Polish
        Thanks for the info.
        Bit of a newbie question. Is it worth using No7 before these polish/waxes. Or will they just take off the polish.
        Thanks Shane.
          Re: Polish
          If your vehicle has base coat/clear coat then M7 is not really needed. A cleaner wax will remove anything that was previously applied.
          Have you considered going to a dedicated polish (ultimate polish or M205) instead of a cleaner wax?
            Re: Polish
            A cleaner wax would remove the polishing oils.
            You could use a stronger cleaner before if needed, or a regular wax after fir a second coat.
